AFE air filter stage 1 or 2
Originally Posted by isissound
would the scotty II drop egt's any more and would it allow better air flow i am looking at that because i can get that with a pro guard 7 filter now
as i jest told scotty i will let you all know as soon as i find it again because i am going to order one
How to get better mileage
I Have An 02 Dodge 3500 Diesel. 5in. Exhaust, Hypertech 3 Stage, And A Stock Air Filter. Will Larger Injectors Get Me Better Mileage And Should I Get A Different Intake? I Get Approx 16-17 Mpg Empty And Approx 11 Pulling A 30 Ft Gooseneck. Any Help Will Be Appreciated.
I'd say you need an air filter system of some sort. Any power increases really tap out the stock air filter. More often than not you can cause some leakage past the stock filter brick gasket. Mind you I don't know if the Hypertech comes with a boost elbow or not.
The mileage on the Diesel is most affected by timing and fuel injection quality, oh and the driver..
I'd highly recommend getting a scotty 2. They flow the best, they look the best, and they sound wicked with the hole cut. And as it turns out, scotty is having one heckuva a sale going on right now. You get his intake and his fuel system for $309. That's a great deal. Check it out here http://www.scottyairsystems.com/pricing.htm .
scotty filter system
ok thanks for the info. should i get new injectors as well and if yes, what kind do you suggest. also when i run the engine up to approx 2700 rpms it cuts out. what do you suppose that could be?
P0216: Fuel injection pump timing failuer (AKA death code of the vp44)
P0460: Fuel level unit no change over miles
P1694: Fault in companion module
P0122: APPS signal voltage too low
P1693: DTC detected in PCM/ECM
gdlukn,
I would get some Formula 1 injectors. Some 1.2's would give you the best mileage, but the 1.6's yeild an mpg improvement plus a nice HP improvement.
Doug
Doug
0216 is your injector pump (VP-44)...in most cases, your lift pump is dead as well.
If you had a FUEL PRESSURE GUAGE you would have saved yourself a few thousand bucks.
Hopefully, your truck is still under warranty.
So, did you find that Proguard 7 part number or link?
Top's Younger Twin
The reply we got from AFE is there is a 9" filter with less flow then the 14".
They do not have a 14" proguard replacement crossover for the 20-40044.
Scotty
Scotty
nope!!! but i'm still lookin
sinawalli
03-05-2011 08:43 PM
TORQUE BEAST
06-08-2008 07:53 PM
goodeyesniper75
08-29-2007 11:54 AM
052500#1
13
01-06-2006 03:27 PM
