AFC Mods
AFC Mods
Will the stock AFC limit high rpm fuel set about 1/3 back from full forward? I now have a #100 plate set at 1/8" back from full forward. I have not adjusted anything internally on the AFC. I would like to decrease the smoke at lower boost levels but my truck can use more fuel at 35psi boost at the upper rpms.
Thanks, Perry.
Thanks, Perry.
I removed the AFC and swapped the washers. The foot will now go full travel and touch the housing. I backed the zero screw out about 3/16" and slid the AFC full forward on the pump. I then tightened the starwheel to control the low boost smoke. The truck feels stronger now, I should have done it sooner.
Now if I can just get my eBay boost controller adjusted correctly.
BigBully
09-05-2007 09:34 AM
royta
02-15-2005 10:15 PM
