Aero turbine shoot thru the heart of a droone
Yes my AERO TURBINE muffler is guilty of murder, and in the First Degree. Today I got a chance to do alot of highway miles and much of it at 80-105 mph, the DROONE is dead. I had a droone at 2000-2100, and I installed the AERO TURBINE muffler to see if I could not get rid of it. It worked, no drone, and I search around to see if it had moved to a different rpm range, but nope it's gone. Big test will be when I tow something, but for now, I am pleased. No I am not one of these "I don't like a diesel to make noise" people. I love the sound of a tightly strung 12V, but just want'd the droone to go. So I am passing this info along to those that maybe feel the same way. This was my first hard run, and man can she scoot. I also went up 3 clicks on the AFC and it made some difference......I love this truck!
Also wanted to stress I installed this Aero Turbine in front of the system muffler. I use the Hog Performance ss 4" exhaust system w/6" tip.
Muted User
Re:Aero turbine shoot thru the heart of a droone
ditto... i've had my aero turbine for a couple weeks now and love the sound. Its loud when you want it to be, but without the drone of the straight pipe. these mufflers are advertised to give you better milage also, i have seen a little bit of improvement. This is accomplished because the muffler is designed to create a vacum. Of course extra money just for a muffler seems hardly worth it, but since i got mine for free i'm extremely happy with it.
do you run this without a muffler? Also how about for 4" exhaust. I got a 4" system from Jannetty Racing to move air like a 3" straight pipe system, but to get rid of the drone. I love the sound of a straight pipe. any help!! Thanks
I guess the question was directed at me??? I put the AERO TURBINE muffler in front of the normal system muffler (that would make two mufflers,yes), I love the sound of a diesel, but didn't want to listen to the drone I had at 2000-2100 rpm. If it's bad now, wait till you tow. So this was an experiment kind of, and it seemed to work. The two mufflers are both located in the strieght section of the system, and the Aero muffler is 10" in front of the system muffler.
Muted User
I am not running any other muffler with mine, just the small aero turbine muffler. I cut out the muffler that came with my 4" exhaust kit, and stuck it in its place. I really like the sound. pretty much straight pipe loud, but quiet in the cab when cruising down the freeway.
MikeyB
33
03-05-2005 02:40 AM
big_gatti
02-09-2005 07:41 AM
BADodge2003
09-24-2004 06:10 AM
signature600
12-01-2003 04:41 PM
snakefarmer
11-18-2003 12:15 PM
