AEM water/meth inj., anybody used it?
I've been wanting to put a water/meth injection kit on my truck for a long time and am even more tempted because of a sale on the AEM unit that comes with the 5 gallon tank. I only want it to try and drop EGT's on a long grade I have to climb every time I have my 5th wheel hooked up. I literally have to climb this grade staring at my EGT gauge for 30 minutes while trying to drive. I only plan on running distilled water no meth since I still have a stock head gasket.
Anybody have any experience with the AEM kit? I know better kits are available, but I'm not really interested in spending that much money. Thoughts/opinions?
No experience with AEM but I have a Snow setup for the exact same reason you're wanting an injector.
Been running 100% -45 washer fluid in it with stock head gasket for over ten years now, no problems.
Drops egts about 150 instantly.
I have to modulate the pedal to keep it under 1250*.
Infidel, unfortunately in Southern California I have never seen the cold climate windshield washer fluid. I have searched every auto parts store, Walmart, Target and truck stop and always come up with just the normal stuff with no methanol. I can buy methanol and mix it myself but I don't know if a low percentage does much more than just water.
Any more thoughts or opinions on the AEM kit?
So do the manufacturers of washer fluid make a special California blend then? Cause if you go look at some MSDS sheets the fluid has methanol in it.
BossHogg
10-30-2010 08:24 PM
DIESELWRKS
10-03-2010 03:35 AM
TurboTurd777
10-02-2008 10:56 PM
