AEM Heatshield Install
Hey all!
I recently purchased the AEM HD Dryflow Kit with the heatshield, and I am stumped on the heatshield installation. To initially secure the heatshield, you have to remove the 13mm screw from the the inside fender wall.
Here's my problem, the hole does not line up perfectly with the heatsheld's hole. I have no room to get the 13mm screw in, even though I was using a 3/8 inch extension. The only other thing I can think of is to completely remove the passenger side battery so there is adequate room to work.
-Is this feasible?
-Have y'all run into the same problem?
-What other ways can it be done?
Thanks in advance!
-Is this feasible?
Thanks in advance!
i have the aem kit in mine...i cant imagine what the problem would be...mine went right in no problems, without removing the battery...couldnt have tooking 20minutes to do the whole thing....
masonic-dodge
11-08-2004 10:53 AM
