Advice on turbo upgade for 1995 12-v
Old 12-27-2011 | 10:24 AM
SKATERHAULER's Avatar
Here is a list of what has been done and it runs and performs well, however we always more . I want to grade my turbo and reall want to imporve low end spool-up/ boost . I spend 99% of the time under 2000 rpm and only spin up to 2500 when racing . Stock turbo will deliver 40 lbs under full boost and egt can easily reach 1300, so that is why i need more boost . Here is what has been done Is there a set-up that will deliver quick low end spool up and deliver upstairs ? Twins ?
1995 ram 2500 2 wd
3 inch body lift
3 inch susp lift
325-70-17 nitto terra grappler
viper red paint
adjustable air bags ( rear )
12 valve cummins
3200 gsk
removed # 4 plate
16 cm ex housing
4 stainless ( 316 ) inch turbo back
true ram air
goerend triple disc
goerend vb
tq lock up switch
arp head studs
gauges , glow shift , hate em
stage 2 ddp injectors
fuel plate delete
dodgemaniac
Competition / Pulls / OffRoad
07-31-2008 11:15 AM
ro9beam2002
03-16-2008 12:35 PM
97CTD
10-10-2002 11:11 PM
