adrenaline tunes
Old 04-05-2009 | 01:27 AM
  #31
J Lent's Avatar
Originally Posted by qzilla
I dont know for sure yet (because I don't have the truck for it) but, I think we can probably go close to 5,000 rpms. I am not sure how much power can be made since you only have one solenoid feeding all 6 lines so at some point you really have to start cutting fuel back to keep it in time but, I think I can probably go as high as you have cajones for.
I am all bag, bring it on!!!!!
Old 04-05-2009 | 01:44 AM
  #32
Brokenarrow's Avatar
Well i can send you my quad tommarow! And i can gurantee my truck is capable of 5000 RPM! It used to be ppumped coming off the line at 5500! if you dont beleave me i can send you a few videos of the truck while it was ppumped, and a few videos of now when it was VP! Nothing has been changed since then except pumps and injectors!!!
Old 04-05-2009 | 02:03 AM
  #33
J Lent's Avatar
What made you go back to vp?
Old 04-05-2009 | 09:52 AM
  #34
RacerRon's Avatar
This is strange. The new 3000 tune runs great and the gear position works well also (6speed) but, when in warm up mode (pop up flashing warm up / level 0 ) the power level center right reads "22". After warmup it changes to "10" . This tune definately hits harder than the old 2000 tune. I had the parameters the same on both tunes : can fuel 25 to 100, strech 45 to 100, timing 8 , max strech 1800. So far, no surge.
If I change the power levels from 11 to 4 , will level 4 be the same as level 10 is now ? level 1 timing only , 2 timing and can , 3 timing can and strech ?
Old 04-06-2009 | 04:00 PM
  #35
Couldnt keep the truck together! Was running abushed 3.0 charger in the 2.8 class with a 13mm race pump built by scheid. The truck WAS NOT streetable at all, and it would break something new everyweek!
Old 04-06-2009 | 07:38 PM
  #36
J Lent's Avatar
Makes sense.
Old 04-06-2009 | 11:03 PM
  #37
Rods's Avatar
Hmm 5000 RPMS , I would sell my ppump setup and go back to VP If QUAD can back that up
Old 04-07-2009 | 01:03 AM
  #38
I wish he would give the tune to someone that had a truck capable of turning 5K, Hint hint! LOL
Old 04-07-2009 | 07:49 AM
  #39
J Lent's Avatar
I'm not so sure about a SO pump going over 4500 rpm at most. Maybe the Dragon has a shot, but I'm not getting my hopes up. I'll be happy at 4500. I'm not saying it can't happen, I've already seen Quad do things that couldn't happen. I still haven't seen a dyno sheet with the Dragon, but I wanna know what the pump is capable of.
Old 04-07-2009 | 01:59 PM
  #40
That what really makes me curious is the pump, maybe it can make hp higher up in the rpms
Old 04-07-2009 | 08:56 PM
  #41
scottsjeeprolet's Avatar
I'm relieved to see that mine's not the only one doing it. Freaked me out when i saw "Warm up 0 and PL22". Just updated everything tonight, loaded the 3000 tune. I'll see how it runs tomorrow on the way to work.
Old 04-07-2009 | 09:09 PM
  #42
gotslicks's Avatar
OKOK
why do i have the lock next to my gear selector?
what do i need to do to get it working?
quad when will the 3.55 be updated to the gear list?
btw mine flashes 22 also
Old 04-07-2009 | 10:56 PM
  #43
qzilla's Avatar
The new Pulse update is out. It is ver 1.3.6 and it has 3.54 and 3.55 options in menus.
It also solves the "22" during warm up.
Now, for the gear selector thing to work right you also need the latest Adrenaline tunes dated 4-6-09 or newer. Right now I think 1000g, 2000g, 3000g, comp3 and dyno3 are all updated. I am actually trying to get the rest up right now.
OKOK
The lock symbol is really meant for the auto trucks to show when the torque converter locks up. On a manual truck this will show locked pretty quickly after you shift gears. It should be locked most of the time.
We can only calculate slip% when we are in the "locked" state. You will notice at idle and really low speeds or when your foot is on the clutch or between gears the lock symbol will be in the "unlocked" position.
If you have 3.54 or 3.55 gears, you need the updates I listed above.
Old 04-07-2009 | 10:59 PM
  #44
So i need to update my Pulse again? It's a real pain to get it off the stick!
Should i get rid of the updates from the other day and download the newer dated ones?
Old 04-07-2009 | 11:56 PM
  #45
gotslicks's Avatar
quad
you should come out with some sorta quick disconnect for the pulse.
that way if you need to take it out you dont have so much problem.
also
if i have 37s what number will i use on the tire size?
