Adrenaline trans sending unit
Just curious before I go gettin covered in ATF will the sending unit that comes with the adrenaline fit into the tapped hole on a Mag-Hytec double deep pan? Or do i have to put it where the instructions imply in the test port?
Should fit. The sending unit is 1/8 npt. The mag Hytec pan should tell you what it is.
http://www.mag-hytec.com/transmission.htm
According to the above link it will screw right in!
Thanks for the info
wurkenman
09-11-2010 06:07 PM
GFB
05-01-2008 08:33 AM
Bad Ramer Jamer
30
10-16-2006 10:43 AM
GUAK
04-28-2005 08:14 PM
