Adrenaline Surge Updates
Old 11-02-2008, 08:50 AM
  #406
GFB
GFB's Avatar
Originally Posted by J Lent
Have you tried to eliminate it with custom tuning?
Or at least try the J's pump stretch and timing recommendations? Wow they really woke my truck up. 2200 fuel stretch, 10 timing with 75% scaling. Breaking the tires loose from a roll in third gear = fun.
Old 11-02-2008, 09:00 AM
  #407
RowJ's Avatar
No! Still breaking in new head/gasket and taking it easy. Only played with newest ADR1000 on hwy at cruise!
Any suggestions. (probably need to read this thread for the last two weeks ).
Thanks GFB but what does that have to do with surging?
RJ
Old 11-02-2008, 10:10 AM
  #408
GFB
GFB's Avatar
RJ
Not sure but it sure is fun. Actually it doesn't surge on my truck though, so in a round about way I guess it fits with the thread.
There's been nothing but smiles in my truck since I've started playing with the custom tuning.
  #409
gotslicks's Avatar
when you say 75% scaling what do you mean?
i thot the scaling was psi based?
Old 11-02-2008, 10:11 AM
  #410
GFB
GFB's Avatar
There is a max timing setting, but also a timing scaling. See my post in this forum where I got an explanation of it from quad.
Old 11-02-2008, 10:42 AM
  #411
RowJ's Avatar
... Actually it doesn't surge on my truck though, so in a round about way I guess it fits with the thread.
I will try it soon! Actually makes some sense. I've seen it where I got less surge from ADR2000 than ADR1000, so it may be better?
EDIT: 12:30 - Just tried new (10/21) Comp Tune, no custom tuning, on Hwy at 60, 70, 80 mph. NO SURGE!!
Glad I waited before filling in surge form on Quads Web site!
RJ
Old 11-02-2008, 01:19 PM
  #412
xtoyz17's Avatar
EDIT: 12:30 - Just tried Comp Tune on Hwy at 60, 70, 80 mph. NO SURGE!!
RJ
After putting about 1k miles on the new tune, the truck surges only a SLIGHT amount, but has great power. Doesn't surge at cruise, or WOT. It only surges when I accelerate at maybe 50% TPS, and start to lift as I approach my desired speed.
It's so minute that even though it needs the new firmware, I'm in no rush to get it fixed as I'm very happy with it in every other way.
Shawn
Old 11-02-2008, 04:03 PM
  #413
J Lent's Avatar
RJ
With big injectors, try lowering your fuel stretch a little. Then play with the tps min & pump min settings, set both minimums at 30 & see if that helps with the surge. The lower the min settings, the more aggressive the fueling off idle.
Old 11-02-2008, 05:40 PM
  #414
gotslicks's Avatar
j how do you feel about scaling the timing?
are you just using 100%scale and 10* or scaled?
Old 11-02-2008, 07:07 PM
  #415
J Lent's Avatar
I haven't played with timing scale yet, my truck is still down. When I get it back, I'll mess with it.
Old 11-02-2008, 08:13 PM
  #416
qzilla's Avatar
RJ
You are close enough to us that you should really swing by one day and let us do the upgrade. It will take less than 5 minutes, in and out total. You have an auto and big sticks, that is the worst recipe for surging and I think the firware update will fix it 110%.
Worse case scenario send it to us and we can turn it around the same day we get it.
Old 11-03-2008, 07:39 AM
  #417
RowJ's Avatar
Thanks, but already done. See post #403.....
"Finally got my truck back on the road. Tested today with new hardware & software."
RJ
Old 11-05-2008, 10:32 PM
  #418
bootsdodgejn's Avatar
well i think i will be filling out that form for firware. Had a good couple suges on the comp tune at all levels after 3.Ill try it out again and see whats up.
Old 11-07-2008, 04:22 PM
  #419
Tiger Rag's Avatar
I just ran the new comp tune in my truck. It ran great and surge free on level 3. The problem is that I could not get the level to increase past pl3?
Unplug and plug back in?
Old 11-07-2008, 05:21 PM
  #420
qzilla's Avatar
Nope, you probably are running Tune 1 or Tune 2 by accident.
Go into the custom tuning menu and select the Factory Default as the tune you want to run and see if it returns.
If that does not work go into the menu and see if the # of Power Levels is set to 4. 4 Power Levels = 0-3
PS. I bet the jump from PL02 to PL03 is quite large!!!
Quick Reply: Adrenaline Surge Updates
