Adrenaline Surge Updates
Old 10-25-2008, 09:14 AM
  #361
bnold's Avatar
I have another 500 miles or so on my test tune from quad... So far I am still surge free and extremely pleased! I have felt it try and surge around 20% TPS on very light accel around 1400-1500RPMs, and I have tried to make it worse... Holding the throttle constant, trying to stay in the 'surge window', but I cant make it happen.... As soon as I think it is going to happen it is fine again! have towed light empty single axle trailers up to around 35k gross on PL03 with no problems whatsoever...
Extremely pleased... Great job Quad!
Old 10-25-2008, 12:55 PM
  #362
BigB82789's Avatar
Set your can min & pump min to 30, bet it smooths out the surge.
I don't have the pulse.
Old 10-25-2008, 01:07 PM
  #363
J Lent's Avatar
Oh, sorry. Repeat after me "Note to self, get a Pulse."
Old 10-25-2008, 01:16 PM
  #364
busta's Avatar
you are only getting half of the experience of the adrenaline without the pulse
I gotta try some of these tweaks as the comp seems a lot weaker then the 2000a test tune i was using
Old 10-25-2008, 01:23 PM
  #365
J Lent's Avatar
I'll bet you don't say that after you try the settings I posted.
Old 10-25-2008, 07:24 PM
  #366
xtoyz17's Avatar
Loaded the new software on the old box and no surge!
Pretty happy with it. Gonna give it some more testing to make sure it's 100% gone, but in a short drive I tried to repeat the surge in a few known areas and couldn't.
Looking good so far though...
Old 10-26-2008, 10:12 PM
  #367
cstroup's Avatar
I ran around this weekend and it was real pleasant until Sunday night I had to tow, and the nightmare returned. Has anyone had to send in and get firmware update yet if so did it work?
Old 10-26-2008, 10:15 PM
  #368
marine4life's Avatar
Custom tuning is amazing. Insane power with no surge, I tried all day yesterday to get it to surge, nothing. Good work quad!!!
Old 10-26-2008, 10:48 PM
  #369
Big Blue24's Avatar
Yesterday I updated to the Comp 10/21 tune. I found it to have a noticeable increase in bottom end power. Makes it much easier to light up the tires from a roll on. There also seems to be zero fuel on, off, on, off, on, off in the higher PL's above 2500 rpm. On the old tune my truck did it a little but nothing major, this tune is truly smooth as stock on my truck.
Old 10-29-2008, 01:49 PM
  #370
ramcummins's Avatar
How do the tunes line up?
Obviously the 1000 is the least aggressive then the 2000 is next then the 3000 then what the comp or dyno?
As far as the 10/21 updates what is everybody using?
Also as far as getting the pulse updated without a laptop has anyone cut the wires and put a quick connect so they can take it in and out of the truck easy or are you guys pulling the wires everytime? I havent updated mine yet because of the wires what a PITA. I guess borrowing a laptop would be the easiest huh?
Old 10-29-2008, 02:40 PM
  #371
Big Blue24's Avatar
Laptop is the only way to go. I had to remove my pulse for a memory update, it was a pain!
Old 10-30-2008, 02:25 AM
  #372
Obben's Avatar
I put a Neutrik 5 pole XLR on the cable.
Neutrik XLR
Pulse is in/out on 2 sec.
Its a common connector for proaudio (ie mic conector) and pro lightning eq.(ie DMX protocol)
Old 10-30-2008, 05:01 AM
  #373
wurkenman's Avatar
I did this. Put on these on. Makes it so much easier. I do not have a laptop, so this was also much cheaper.
http://cgi.ebay.com/ebaymotors/DEUTS...mZ370083960044
Old 10-30-2008, 06:03 AM
  #374
mahdey's Avatar
ran the comp 10/21 tune, surge is gone finally.
Old 10-30-2008, 02:42 PM
  #375
ramcummins's Avatar
Thats exactly what I was thinking about. Thanks.
I wish Quadzilla would have thought about this before they started production. Maybe on their next series
Any body know the order of the tunes?
Quick Reply: Adrenaline Surge Updates
