Adrenaline Surge Updates
Old 09-25-2008, 06:36 PM
  #196
Marine's Avatar
So I can update the Pulse, as well as the Adrenaline?
Old 09-25-2008, 07:37 PM
  #197
qzilla's Avatar
Ok, it looks like it might be a day or two so here is a cheezy way to get a couple of files to you guys. This is the only way I know how to get these out immediately as it might take them a day or so to upload all 50 or 70 files or however many of them we have nowdays!
This site is free, it makes you wait for 45 seconds to download it if you are not a member but, if you just wait it will let you download it for free.
First is the 1000a tune. This should be considerably smoother than all the rest. It might be slightly soft but ,the Custom tuning is enabled and it is easy to turn the fire up! This file also has the fix for the module overheating issue. It has all the parameters turned on like IAT as well. This needs to be used with Pulse ver 1.3.2 that is available on our website.
http://rapidshare.com/files/14842610..._TEST.exe.html
This is the same file with added fuel stretch, and changes in throttle response. You can look at all the parameters once you get it downloaded into the module.
http://rapidshare.com/files/14842790..._TEST.exe.html
Please report any problems or issues ASAP!
You should also be able to update these with Vista or XP with no issues.
Old 09-25-2008, 08:05 PM
  #198
J Double's Avatar
I was able to download the 1000a tune, but it won't open for me.
Old 09-25-2008, 08:11 PM
  #199
bootsdodgejn's Avatar
It opend for me just have not loaded it on the adrenaline.
Old 09-25-2008, 08:24 PM
  #200
J Double's Avatar
Got it that time. I was using "Flashget" as a downloader and it must have jacked it up somewhere along the line. Deleted Flashget and downloaded it again, opened right up.
Old 09-25-2008, 10:15 PM
  #201
well downloaded both the pcm and 1000 tune. I do have to say i dont like it. Right off the bat the truck ran like crap. It was running rough. Then just downloaded the 2000a tune, now it started poping around 2000 rpm. I do have to say i am not imprest at all now.
Old 09-25-2008, 10:41 PM
  #202
qzilla's Avatar
There has to be something wrong?
If it is running bad, then put the old tune back on. I have tested downloading from that site before but, it is possible something is corrupt?
Can you give me some details, PL01, PL02, are they ok? Does it start at Pl03 or higher?
What exactly does "ran like crap" mean? No power? surging? no throttle response? What exactly was running rough? Idle? only when you are running it? what power level?
Now, on the 2000 tune is all the above still true AND it was popping?
Please try to explain. Was it popping at WOT or with any throttle?
I want all the answers I can get but, if it is running poorly then please put the old tune back on it. If you need the old tune pm me with your email address. I don't want to take a chance on you messing anything up at the expense of a bad download.
Old 09-25-2008, 10:52 PM
  #203
qzilla's Avatar
ok guys, I killed that link, you got me scared there is something wrong with the download.
For those that downloaded it please give me a report as soon as you can. IF this is in isolated incident I will put them back up. If not delete them!
Old 09-25-2008, 11:53 PM
  #204
I just sent you a pm, to make it easier.
Old 09-26-2008, 06:01 AM
  #205
scottsjeeprolet's Avatar
Boots did you update your Pulse first to V1.3.2, before loading the new AD tunes?
Old 09-26-2008, 09:35 AM
  #206
Marine's Avatar
I downloaded the Comp tune after I had the 1000 old one on. It bucks like crazy. I will put the old 1000 tune on until the new tunes are out.
Old 09-26-2008, 10:11 AM
  #207
ahire's Avatar
I found some thing yesterday while cleaning my battery terminals. The positive terminal on the driver side has a stud that runs threw it. I knocked it out and found it was corroded pretty bad on the inside. I cleaned it with the bench grinder and it seemed to fix my bucking around 1800 rpm's. Might have just been a coincident. Im running the comp1 tune by the way. It will still surge if i lug the truck a little but the bucking is gone. It makes since to me because electronics act up when faulty powers and grounds are involved.
Old 09-26-2008, 10:43 PM
  #208
busta's Avatar
okay updated adrenaline with the adr 2000A test exe and soon as i started the truck got cel P0237 had it before and put new boots on and cleared it.
dunno if this is related to the new 200a test tune or have to chase another leak or connection
it ran kind of like crap but think it is in limp mode for cel and not tune
Old 09-27-2008, 03:14 PM
  #209
Well i loaded the 1000A tune and she surged like crazy. Are the tunes up on the site the new tunes or the same old tunes?
Old 09-27-2008, 03:41 PM
  #210
same here scott i got the 2000a and it surging like crazy to.
Quick Reply: Adrenaline Surge Updates
