adrenaline+SC programmer?
Alright i finally figured out how to fix the speedo on the pulse but the speedo in the truck is still way off. so if i loaded the superchip programmer to fix the speedo i would have to tune the truck also. if i put it on the lowest setting what kind of timing should i run on the adrenaline?
I'd be warry of using both. SC adds fuel & timing. Adding more timing with Adrenaline is going to be too much....not good. I ditched the SC as you can see in my sig. Overall it adds a nice boost in power but nothing when compared to the XZT+ and it's features.
i already have the adrenaline with pulse and i can take the timing out of it. i was just throwing it out there to see maybe if someone had tried it or if they knew how much timing the sc programmer adds
I can't believe you're slipping that clutch with just a stock turbo, 100 hp injectors and the adrenaline. Lots of fuel but only 400 HP worth of air, isn't that clutch rated at 500 hp or so? Is it the 13" upgrade or the 12.25" ceramic clutch?
no its the 12" i should have went with the 13" but i got areal good deal on this one. plus i was in a bind at the time and needed something now but its always shoulda, woulda, coulda around here.
mopar440cu
11-21-2015 09:39 PM
bnold
2509
07-24-2008 11:57 PM
qzilla
218
01-30-2008 09:20 AM
vzdude
10-17-2007 05:32 PM
