Adrenaline Problems
Adrenaline Problems
I have an 01 with an Adrenaline box on it. i was wondering if anyone has had the problem of changing the power settings and the power settings decreasing whenever the truck is turned off and turned back on. I can normally increase the power settings while i'm driving but can not bring the power setting back down when the truck is running. i have to turn the ignition on and off several times until it reaches a lower setting. each time the truck is turned on/off, the power setting will go down whether i want it to or not. any ideas??
yeah everything is hooked up, i have had problems with it not turning down on the fly since i have had it. i re-loaded the ADR2000 and it was working great for a day. now its back to the same problem i was having. wasn't sure if it was the box or just the in cab monitor.
Best bet is to call quad. That's a hardware/warranty issue most likely, and there isn't much that us laymens would be able to help with.
Short of making sure everything is installed correctly, and/or reflashing with new software there isn't much I can tell you to do.
isu elvi
06-20-2008 02:39 PM
ramcummins
18
06-07-2008 12:35 PM
