Adrenaline problems
Adrenaline problems
After reading all the hype about the Adrenaline I ordered one and got it installed today but now I can only hit 35# of boost with my old drag comp I could easily hit 45# . I have plenty of fuel any one have any ideas .
The Aggressive files will change your mind about the lack of boost. I had my wastegate set at 45psi & never went over that with the Drag. I haven't touched the wastegate & boost goes over 50psi now.
Can you tell for sure that the other levels are adding fuel? This would be PL03 and up?
If not you might check the wire tap and make sure you got a good connection.
I can run 50psi easily with stock injectors.
The weather took a dive before we could hook my Drag box back up just to see if it would still hit 45lbs. If he can hit 45lbs with the Drag there's has to be somethig wierd going on with the wiring harness or Pod since we've tried two different boxes and three different tunes. If it doesn't hit the high boost we may need to check for a boost leak.
Well I found the problem .The plastic tubing going to my boost gauge got cracked and made a boost leak . Fixed the tubing and now I can hit 48# of boost .It does feel a little stronger than my drag comp alone I think I am going to really like this adrenaline .
mishkaya
I have tried hooking it up when it is searching and have tried many different ways but still no luck .Right now I have to go over to J Doubles house and load it on his computer .
isu elvi
06-20-2008 02:39 PM
ramcummins
18
06-07-2008 12:35 PM
