Adrenaline Owners with Surge/Buck
Old 09-13-2008, 02:25 AM
  #31
luke@ddp's Avatar
Originally Posted by EBunger
What is everyones TPS at idle? Mine is about 8-10%
TPS @ idle should be 0%
Old 09-13-2008, 03:27 AM
  #32
EBunger's Avatar
I misposted I meant Load %
Old 09-13-2008, 10:30 AM
  #33
00BRam's Avatar
Mine is Bucking, only between 1500 - 1800 rpms,I think it is trying to fuel 100% and I am trying to hold steady throttle up grades. That is the only time it does it, it hazes the whole time up the grade, no puffs just strong haze. If I don't back out of it and let keep in it and speed up it doesn't do it.
Tunes I have tried: ADR 1000 & ADRComp the recent one
Between 1500 and 1800 rpms
Boost is 10 - 15 psi
I can check the TPS and Load if you need me to
Thanks Matt
Old 09-13-2008, 10:41 AM
  #34
bnold's Avatar
been running the 1000B tune on the website and LOVE IT!!
This is the tune I have been waiting for! No bucking, no surging, I can tow with it on PL03 and power is smooth and very light until you get above 40-50% TPS or so... Perfect for having a trailer in tow!!
Tune is still more than capable to put the truck over 65psi, and makes good power with little to no pop at RPMs near redline...
This is a great daily driver for me (For the first time since I have owned this box I can leave the power on PL03 and just drive! Normally needed to turn it off), now for track use or the like I would probably load ADR2000 or ADRComp which is PERFECT for ME!!
Great job Quad!
Only issue I have with this tune right now is no tuning option in the pulse?? Everything reads 0 0.0 00 etc... guessing this has been covered previously?? Maybe I downloaded the wrong one? With a steady accleration (30psi or so) I can increase PLs## one by one and feel the increase in power so I knw that the tuen is there, just maybe not the custom tuning options..... Now that I think about it, dont know what I would touch it works great now!!
Old 09-13-2008, 03:19 PM
  #35
RacerRon's Avatar
My engine load % is 8 to 13 % depending on if A/C is on or the fan clutch is engaged or not.
Old 09-13-2008, 04:24 PM
  #36
pearlbronze2500's Avatar
Quad I have the ADRCOMP tune on mine and I wouldnt say it bucks or surges but on anything over level 4 it runs very rough when lightly accelerating or holding the same speed. I would describe it as missing but it has a soft knock with it as well
DieselVeins
06-28-2010 08:52 PM
DodgeRamdiese01
19
08-30-2009 08:38 AM
qzilla
492
11-24-2008 01:42 PM
qzilla
10-16-2008 05:43 PM
Ram of Steel
05-24-2007 10:11 PM
Quick Reply: Adrenaline Owners with Surge/Buck
