Adrenaline not working
Well the adrenaline worked good for some time, and all of a sudden it quit working, shutting the truck off and unplugging the adrenaline box and plugging in again. fixes it for that time, but once the truck is being shut off again, it doesnt work unless i unplug / plug it in again.
Also im NOT happy with the buttons on the pulse.
also i bought a universal 100 psi fuel pressure sendor and its not working right, it shows 18 psi min, when truck is shut down and has 0 psi in reality.
should i send it in to quad?
the fuel pressure sender has to be the correct scaling or it won't work with the adrenaline. buttons are common problems. it's a quick fix if you take the pulse apart and scotch brite the pads. do a search for it, it's around here. quad will send you new buttons if you want. did you try updating adrenaline or pulse? that might help.
i would send it in to quad to have the firmware update anyways, my adrenaline acted completley differant after the firmware update, it is well worth it to send it back in.
i thought i had read quad suggestewd this sensor: so i bought it
http://www.egauges.com/vdo_indS.asp?...SI_US&PN=R8917
ive updated the adrenaline, didnt help.
Thanks guys, didnt know how it worked!
I contacted them now.
BTW i never sent in the warranty registration card, will i still get it fixed for free?
Sleigher
05-04-2017 02:12 PM
southpawslingr1
07-09-2008 08:44 PM
NHDiesel
09-02-2005 11:23 AM
