Adrenaline... me likey!
Ok i have had several complaints since i bought the adrenaline.
Now i just wanna share a few things about it.
i had it sent in to quadzilla to have fixed, and updated to the new firmware and put in new buttons on the pulse.
The buttons work way better now, but the wire tap kept kicking out since the upgrade (SW problem) so it gave me only half power, sometimes when i needed it the most...
i updated it with the 3000G version, that has the bug fixed, and i really like the box now.i also run bosh 275 rv injectors
I blew up my hx35 turbo, at 37 psi boost ?! the other day while i was racing a Dmx... good thing it happened when i already had him behind me.
i have a lock up switch on a stock tranny, i know my TC is gonna be toast soon, maybe ill just wait to put in a new one, till it gives up on me.
I enjoy it everyday, tires break loose when i start florring it at 40 mph
Thanks quad for a great box! and for the warranty fix/upgrade!
So these new tunes for the Adrenaline are starting to work out for everyone?
I was a little nervous thinking whether I should purchase the TST PM3 or Adrenaline. But with these new tunes looking like they are fixing things, I may be getting the Adrenaline.
Good to hear that you got your truck all figured out. Are you running just the Adrenaline, or Adrenaline and Pulse?
Yea every thing seems to be in order now, working good. I almost gave up on it and started buying its replacement parts. Glad it came around, no where else can you get the features and options for the money.
The new COMP tune is working flawlessly for me, as well. I love having the Pulse monitor along with the Adrenaline. Makes everything easy to access and there are a ton of different features.
i am running the adr torq tune, it was a little rough on my truck at first, when you let out of the pedal it would act weird but i changed the can level and it works great not even any surging when cruising, the only thing that i dont like about it is that if you change the tuning and save it the fuel stretch will only save to 2200 not the 2400 in the new tune. but its a pretty nice tune i have been running it for a couple days
I've been running the TORQ tune for almost a week now. It's definitely smokier, I just don't know if I can tell much of a difference between it and the COMP or not. I might try doing some custom tuning and see if I can get anymore out of it.
i like the torq tune real well, i leave mine on 10 and drive around everywere and it seems to do ok, not alot of differance between it and the old comp tune, it is a little more responsive, but it is running really well on my truck, i just need a little better clutch
Howy
11-12-2007 02:04 AM
MmmDieselFumes
10-05-2007 10:55 PM
