Adrenaline makes hp over 3500rpm!!!!!!
#61
http://www.quadzillapower.com/produc...ta-USB-Updates
6 new updates that should suit everyone to some extent
#62
Quad......
What's the lowest TPS Max % you would recommend for the Dyno2 tune.... to get earliest, smooth, full fuel stretch, on the dyno.
Will too early (low Max %) run the VP-44 dry to early?
I assume both on PL10?
Going to save, and dyno, both Comp2 (t-1) and Dyno2 (t-2) tunes.
First run with Adrenaline off, I think (for baseline with new injectors), then one run with each of the above.
RJ
RJ
#64
Oh, and that wasn't letting out of the throttle. It just stopped reving and the tach fell and there was silence. I let it sit for a min. or two and the Fass pump came back online and it fired right up..
#65
I think Quad may have turned the fuel up a little too much. It happened with the old dyno tune, maybe it is happening again. Something wierd happened to me today also. I started my truck & it went into high idle. I walked into the house & heard my truck shut off, went back out & it wouldn't start? I checked the fuses etc. because my fuel pump wasn't running. Got back in, fired right up & had pressure. I thought that maybe I pulled a wire off somewhere when I removed my Redline box today, but nope? I'm running the comp tune from last month, no issues until today.
#66
my truck did the same exact same thing a while back i reved it up a bit to show off to some guys and it died fass quit running i gues it tripped the relay waited a few minutes and fired right back up. thats really weird how that happens.
#67
is stretch based on tps in this tune?
whats the difference in new comp2 tune.
#68
I just got my springs in the mail! Cant wait to get on the dyno and see how the Adrenaline works on my truck. Whats make of spring compressor should a guy get?
#70
http://www.sourceautomotive.biz/comp...cfb2f0fec6.jpg
#71
I also got Hamilton springs, I could get on the list for the tool but I saved enough on the springs from when I was originally going to buy them I think I will just buy the compressor. That source automotive tool looks pretty slick. Who makes the other one that you dont have to remove the injectors?
#72
I think www.uintadieselperformance.com sells the tool. Marc is a good guy, treated me right when I bought the springs, then sent me a compressor to do the job.
