Adrenaline and Fuel Pressure
If we order the Adrenaline should we order a Fuel Pressure kit also. I read some people are not getting the FP kit with the Adrenaline itself. Will ordering the 0-40PSI FP kit from Quad solve the problem? Is it compatible with the Adrenaline contol pod?
Thanks
Thanks
If you pre-ordered an Adrenaline and it didn't come with the FP sending unit, there should be a note in the box to call Quadzilla or send them an e-mail with the number that is on the note, this way, if the sending units come in, they can send you one.
If ur Adrenaline was not pre-ordered, then you do not recieve a sending unit. As stated, Quad was having a supply issue and decided not to inclued the sending unit with the Adrenaline. NAPA and a few others sell a 0-80psi sending unit that should work just fine.
There is no online registration for the FP sending unit if you did not receive a note with ur Adrenaline. That is how I understood it. Just give Quadzilla a call if need be.
wurkenman
09-11-2010 05:07 PM
redneck2thamax
01-25-2010 07:00 PM
SpunkysRam
08-17-2008 01:14 PM
GFB
05-01-2008 07:33 AM
