Adrenaline for Dummies
#32
From post #3 in this thread
I did a little editing to hopefully explain it better.
PL0 is off, but still does boost fooling.
The fuel saver level is PL1.
PL2 is timing and fuel ( fueling only through the CAN-BUS)
PL3 and higher adds timing and adds fueling via the wire tap.
There is no specific setting or HP increase for the different PL's that I'm aware of. All I know is when you push the UP button, the truck goes faster.
#33
So does unplugging the MAP do anything like the Comp?
I think i slipped my TC tonight on PL10?
Are all the Pulse buttons as crappy as mine? You gotta push really hard to change anything. I think my enter button is gonna quit on me.(gotta push really hard and it's only > 1 week old) Could have made easier to push buttons.
So far it's OK. I think i liked my Smarty/Comp stack better.
#34
#35
Well tried the 2000 tunes and WOW, gotta get a built tranny now. Slipped my TC, not happy about that.
Is anyone else having issues with their Pulse buttons? My enter button almost doesn't work at all.
#36
PL03-PL10 progressively add more fuel by stretching the injection event. Different truck (different yrs and different injectors) like some settings more than others. Play with it till you find what works best on your CTD, with your set up and your type driving.
If you have the Pulse, all you need is to download either the ADR1000 (production Tune) or the ADR 2000 (Agressive Tune) and set it up the way you want it ...with the Pulse.
Hot Lock IS for custom tuning and personalizing your own power curve! Not activated yet and not recommended for most, IMO.
PL01 is still timing only...even on Agressive tune. No different than PL01 on Production tune.
Pulse can be updated with key off...still plugged in. Adrenaline should probably be unplugged, but I'm not sure?
Call Quadzilla Performance Technology and ask for 2-3 replacements. They do wear out or malfunction.... nice to have a spare or two. The co is aware of the problem and I know Quad has researched different buttons and it is just not doable on that unit. Most work very well for a long time.I had two go bad before I got a bit more gentle and accurate with my oversized fingers.
To replace, just unscrew the cover and R&R. Very easy.
#37
So the way I understand it is all the adrenaline units are programmed with the 1000 program.
Do you update the adrenaline through the pulse USB port or is there a seperate USB port on the adrenaline unit itself?
#40
ok i just got my adrenaline today and i have got 3 questions
1. the short red wire which goes to the underhood fuse box- it says it has a foot to connect to the fuse and mine had a eye-let on the end. anyone else have this.
2.what does the other wire go to that is right next to the wire that taps the injection pump. it is also an eye-let
3. where and how did you guys mount yours so you could remove it to update it and what not. i know there is 2x sided tape but that seems like it would be a pain in the rear to re-do the tape everytime you wanna mess with it.
also anyone have any install tips!!
Thanks
Josh
Thanks
Josh
#41
Thanks
Josh
Thanks
Josh
2)Is it a long brown wire?? That goes to the tranny temp sending unit (if that's the one I'm thinking of)
3)Are you sure it's 2 sided tape and not velcro?? Mine came with velcro and I have the Adrenaline sitting on the lid of the underhood fuse box.
Short Red Wire = Connect to + side of battery
Long Red Wire = Fuse #9 in the cab
Black Wire with Ring = Negative Battery Terminal
Dark Green Wire = Pump Wire
Yellow Wire = Fuel Pressure Sensor
Brown Wire = Transmission/Oil Temp sensor
Orange and Black with 2 Pin Connector = Thermocouple
#42
There were orange papers in my box telling me to put the red wire directly to the + side of the battery.
The Yellow wire which i thought was the ground for the wire tap is for the FP sending unit that you didn't or anyone get. They don't have one that works.
Just use Velcro and put it on the fuse box.
Thanks
Josh
Thanks
Josh
#43
I also just installed one yesterday but didnt pay attention to the orange papers and cut the eye-let off and put a foot on it to hook it up to the under hood fuse box.Is this ok or should i redo it?
#44
IMO, hooking it to the battery will make a better connection anyway.
#45
Thanks
Josh
Thanks
Josh
