Adrenaline Comp Beta Tunes
#94
Yep wish level 3 and 4 were more like a lighter production tune... Dont know why we cant get a really nice ramp of cruise/tow to kill in the same program! That would be a beautiful tune!
#96
I got my tranny installed this morning & drove around all day for breakin...ooops, I meant break-in. While installing my tranny, I noticed that I had a fuel leak on my outlet line on the pump. I fixed the leak & something wierd happened today...NO SURGING! with any PL running the comp tune. Could it be cold weather changing the manners of the box or what? All I know is that this tune is stronger than my Drag comp on PL05 & gets crazy from there on up. If it keeps running like it has today, WOOHOO! I'm a happy man.
#97
Yeah I am trying to keep mine below 6 untill I get a new tc, levers, and a vb. But on 6 my turbo has never been so loud or have that quick of spool.
The gauge never used to get above 25psi now on the highway in OD locked out at 65 it goes from 10psi to 35psi in a blink wow. And that is the tune that the box came with never downloaded anything yet. The box is so sweet.
#98
I dont know anything about a Smarty, but this thing hits at very slight throttle and doesnt stop pulling until you let off or blow something up.
#99
#100
#103
Based on what Quad said in post # 42, I assumed the revised tune was the only one available? I just downloaded the tune from post #1. Must be revised based on previous reports; JDouble, Wurkingman, etc.
Don't know/couldn't find anything on the two different comp tunes Quad mentioned in post #46 ... so went with only one I could find.
Yup! No surging on way up if 40% throttle or more, but it does 'stumble' when you back off. I only tested PL00 - PL06, up to 3500+ rpm, so not sure how bad it can get. What I did experience was less violent than TST Comp.
It's like Smarty on #20!
Less sensitive from 0 throttle..... smoother acceleration curve, IMO ..... hotter from 10% throttle up .... and pulls hard to redline+++!
And much less smoke.
(Disclaimer - as mentioned I only went to PL06, due to moderate traffic ... and my personal 'sphincter factor').
RJ
Originally Posted by MikeD
Any shudder when you get out of the fuel, RJ?
RJ
#104
OPPS! Can't leave truck on Comp tune for more testing. Just went to truck and engine shut down but Radio never did from earlier test?
Just re-read somewhere that the Comp tune has TT. Thought I solved that problem when I went back to #9 fuse for keyed power?? Everything else shut off with key except radio & Adrenaline Pod??
Quad, any ideas? Had to unplug box to shut it down. Went back to ADR2000.
RJ
RJ
Joel
#105
I didn't see no revised date that was different from the release date on the Comp file so I think it hasn't been refined yet. Quad posted that he was working on 2 Comp tunes, 1 for auto's and 1 for manuals. Oh and RowJ, IMO, Smarty#55 is pretty close to Smarty #40..
