Adrenaline Comp Beta Tunes
Ok, first I want to give a disclaimer!!!!!
This is only recommend for the people that understand the dangers of pushing the limits of your trucks.
I am going to post a link of a Comp tune. It is WICKED but, not refined at all.
I need some alternate input because on our truck it fuels straight to 4K hard all the way but, it will kill it sometimes. I am not sure if this is something to do with our particular truck or something I am doing wrong with the Adrenaline itself.
If some of you guys want to give it a crack let me now how it works.
Ok aside from the fact that it fuels WAY past redline, we made some other changes.
First, it fuels much sooner and does so much harder. It smokes a lot more and we changed the timing up to compensate.
The max fuel stretch is also now greater than before. You may or may not run the VP44 solenoid dry??? You might try lower levels and find out where you run out of fuel now.
http://www.quadzillapower.com/produc...te_98-02b.html
woo hoo! Just in time for dyno runs on the 22nd! Wasn't going to run, but now I am! Thanks quad will hopefully get some run time in soon! Without letting go of your tuning practices, how dangerous is the timing?? Not too worried about the fuel, if it runs dry it does... Been there done that... But timing can lead to HG failures, lots of heat etc... Just want to know what I'm in for!
Stupid question here but will this comp tune have some sort of defueling or in the future??? I know that kinda takes away from the "Comp" meaning of things...
