adjusting fuel plate
a friend of mine has a 95 cummins and he bought a #4 fuel plate. we put it on and there was no stock fuel plate. the engine ran with no plate. is that good to do. and what will it do with no plate in it. also adjusting the #4 plate do you want to slide it all the way back or forward to get the most power. and do you adjust the afc houseing foward or back. thanks for the help
usually a good and bad thing, good power, bad consequences if the arm goes under the pump, u can damage the internals.
Most power out of a plate position? put it about 90 percent forward for most power out of it. Make sure that the governer arm dont run under the fuel plate. Lift the solenoid with one arm with the ignition in the on position and go ahead and see if the arm run under the plate while moving the throttle with the other hand, it can be done, trust me...
Most effect from the AFC housing, comes with the AFC all the way towards the front of the engine, and for smoke control and low end fuel comes ur starwheel,
Again play with all settings till ur comfortable with what the truck is doin
Good luck!
Rick
Dave88LX
31
06-18-2006 04:24 PM
Rockcrawler
14
06-23-2005 11:40 AM
