Adjustable trailing arm?
I have just fit some 35" TOYO's and am having some rubbing issues on the back of the wheel well. I have the 2" leveling kit installed. My question is, would the front driveshaft and steering box/ pitman arm have enough play if I were to install adjustable trailing arms to move the front axle ahead the 1/2" I need to remedy the rubbing? Thanks in advance.
I had a similar problem before my leveling kit running 33" tires. The plastic liner could be pulled back more toward the cab to gain clearance by using a screw.
I beg to differ, but haven't tried yet.
All I need is about an inch to prevent rubbing on the 37's I want to fit in there,
1/2 inch to prevent the stuffed while turning rub I have with my 315's.
phox
Thinking about it.....the track bar on my truck is really close to the front of the pumpkin. I don't think it is possible to gain clearance without a big lift.
On my truck i adjusted the camber bolts on the axle after the leveling kit and it moved my axle forward close to a half inch. I dont have any probles yet everything clears just like stock.
77machomopar
20
12-11-2009 10:37 AM
