About to kill my truckNEED HELP PLEASE
ok im done with the truck and im in the mood to not care no more about it lol Here is what i have done to it,
Edge comp, 275 injecters, cold air intake, 4" down pipe to 5" stacks, trans temp, boost, fuel, and egt guage but egt is broke need new one
And here is what the <edit> is going on..........
Did the lift pump 3 months ago after i did that i had good fuel Pressure 15 at idle and nuttin under 6
Well last week i did the Injection Pump got it back and the truck runs great now but befor i did the pump i was only runing like 25lbs of boost not im maxing out my boost guage that only goes up to 35
WELL this is what is <edit> me off real bad after i did the Injection Pump im now runing 13 14psi at idle and 0psi at WOT so i thought i was runing out of fuel so i put a booster pump in and was at like 20 psi at idle but still 0psi at WOT so i got a new lift pump to day and still doing the same <edit> thing i took out te booster pump and with the new lift pump im still at 13psi and all i dont want to do is burn out the new injection pump
I called one place today and they said with my setup im runign to much power and need a bigger turbo and need more fuel but i kno a lot of you people out there have the same setup
i dont kno what more to day and dont have the more to send the truck anyweres so i need all the help i can get from you guys some one must know what is going on here
Thanks so much
Danny
Thanks so much
Danny
Administrator / Scooter Bum
I'm assuming (there's THAT words again) that you have already changed the fuel filter and tested or changed out the fuel pressure sender (or are you using a mechanical gauge?)
Originally posted by Shovelhead
I'm assuming (there's THAT words agin) that you have already changed the fuel filter and tested or changed out the fuel pressure sender (or are you using a mechanical gauge?)
http://www.dieselperformanceparts.co...unique=C305424
any way one of your batteries is low sendin poor power to the pumps givin ya low press? stranger things have happened....
EDIT: any way to clamp off the return line to the tank from the pump? just for a temp run to see what presure is developed, maybe there is a faulty return in the new injection pump dumping fuel back when it should be holding it for pressure.
the batteries are two months old and are still real good
I haven't been inside an injector pump but seems that the return should be regulated by some means, otherwise you would never get any pressure to the injectors, something has to hold it back to develop pressure. if that "regulator" is faulty or missing then you would get the terrible readings you have since you did the injector pump.
The Best way to Test the fuel Delivery System
Is to pull the fuel line of the VP44,power up the fuel pump or in your case pumps.Put the feed line in a bucket let the pumps ripe.If there are any restrictions in the system,you will see a frothy sporatic flow,If the fuel module in the tank is restrictive this test will reveal it. I think your fuel module is shutting you down.
2500TurboDodge.
Yes, Your fuel lines might be holding you back. My understanding is the stock fuel lines are very restrictive after any big fuel modes. hope this helps
CACalomino
22
05-05-2007 08:55 PM
caleb
09-24-2006 07:36 PM
