I was looking at a fuel plate on ebay they say its #6 or #11 depending on the year of the truck I though a #6 was always a 6 and #11 always an 11 and you use different plates to get a certain amount of HP depending on the year of the truck and which tranny you have!! If you want to look on ebay its #794550465. How do you tell which plate this is?
I could not figure out the profile on the smaller (hp) plate. Definitely some custom grind that doesn't resemble any plate I've seen. Maybe it was the poor photo.
The larger (hp) plate appears to be a #4 knock off.
Are the pumps that differnt? I see on tst 's chart for which plate to use that they have differnt size injector in the trucks with varing HP so is it the injectors or the pumps?
