'99 Oil Filter Tough Access
Old 03-12-2012 | 12:40 PM
stickk's Avatar
Are all the '99's this way? There is access from the top but is not much room for hands and under the filter are a couple A/C lines! Something I may be overlooking?
Old 03-12-2012 | 12:45 PM
infidel's Avatar
I always remove the tube from the airbox to the turbo and it seems like there is a ton of room.
Old 03-12-2012 | 01:09 PM
patdaly's Avatar
This! Took me a while to figure that one out. Just loosen the band clamp on the turbo air tube, remove whole deal, and voila, easy filter change.
Old 03-13-2012 | 12:06 AM
Mike L's Avatar
yeah, pretty much always from the top. Get the airbox tube outta your way and you are good to go. I sometimes have trouble getting a good grip on the filter with my big ham fisted hands. Have had to resort to tapping the outside edge of the filter with a small chisel to get it started. Yes, I know, get offa my back already! Sometimes I do tighten it down a half a turn too far. SHEESH!
Cheers!
Mike
Old 03-13-2012 | 04:35 AM
DodgeRam24V's Avatar
i do that and i also modified my filter wrench.
i took my swivel handle filter wrench and ground off the rivet at the end of the band and put a 1/4" bolt in it.
i take the bolt off the band and slide it around the filter, put in the bolt and remove the filter.
my filter wrench the band will not fit through/under the bottom of the filter.
BlackPuff_Gone
16
07-25-2007 08:30 AM
Cummins Freak
01-17-2007 12:29 PM
BearKiller
01-08-2006 06:29 PM
Dodgezilla
03-19-2005 06:45 PM
