'99 lock-up switch. No jumper on relay?
I just put a lock-up switch on my 99 . I also removed the trans relay and put in a jumper wire. It worked but I got a check engine light,code:manufacturer trans control..
I am guessing you cant jumper wire were the relay was on a '99. Is this true for you post '98 truck owners. The tech sheet I read also said it wouldnt work.
I test drove and fliped the lock up shift as I started in first . It locked in second but the shifts were ruff almost like a double shift into 2nd and 3rd. Didnt feel like it was good for the trans. I was only maybe 1/4 trottle if that.
The switch worked good comeing down a grade with foot off the trottle
Whats the scoop on '99 and later trucks and the lock up switch?
Rick
Rick
Well I just call Dtt and I have a Calif ECM in my truck and apparently a Calif ECM will thow a code with a lock up switch. What a bunch of crap . Calyfornia SUCKS.
I tryed putting the relay back in and then just flipped the switch with the truck running in drive and sure enough check engine light went on again. Ahhh Bullpucky !
12valve
03-27-2006 10:23 PM
mr T
21
06-01-2005 09:48 AM
mazeppa
02-10-2004 07:54 PM
