97 needs body lift help
97 diesel 4x4 needs body lift but everyone i talk to says they dont make one for a diesel can i adapt one the only diffrence i forsee is to shorten pipingfrom air box to turbo,turbo to intercooler, and intercooler to intake can any one help
I put one on my truck,got one for a dodge ex cab with a v10(same year as mine). Worked out good,just had to cut my intercooler to intake a littler shorter.Make sure you loosen your intercooler boots first.
tom
tom
36inch 14inch wide swampers are on the way need the body lift to complement my leveling kit so does anybody know the diffrence other then the filler hose
I put one on mine to cut down on driveline angles........I wanted to clear 38's or bigger but didn't want to have helacious angles in the driveline, especially with putting a lot of power to the ground!! ( which will be happening soon).
I had a 5" suspension lift on mine at first but anything more would give to much angle so a body lift came in handy. And for all of those you say the look horrible, !!! You can barely even tell mine is on there, I have no gaps ANYWHERE and you can hardly see any more of the frame then when stock.
I've had mine on since December and I have had NO problems with it what so ever. And it made working on the engine 100 times easier!!!!
~Nick
~Nick
I have a 3inch body lift also now on my 98, can't even tell it has one one it. Installation was a breeze. Worked great, and would recomend it just to clear a little bigger tire.
really?? I wasn't thinking so much about the look as i was the thought of jacking the body off the frame...i guess thats not too bad of an idea if you want cheap lift and big tires
Hey gotlift or smokenram: do you guys have any side pics of your rigs? (ie to see the body lift/no gaps)
