97 head hights what bulb to get
Old 02-04-2009 | 10:49 PM
drivesmopars's Avatar
i read here that not to buy zeron or extra watt pulbs
ive added the wiring upgrade
tried the extra watt bulbs are totally bad i mean real bad
what are the stock wattage bulbs 7004 that are to get
i read there are 2 or 3 only for a non sport 1997
thanks in advance
bill
Old 02-05-2009 | 12:29 AM
oldblues's Avatar
hi
if you have the wire upgrade i would definatly get the flosser 9104 bulbs !
100/80 watt. they are MUCH brighter than other high watt bulbs i have tried . they are clear no coating !
also you can go to radio shack and buy a diode to install in the one headlight plug you do not use with the wire upgrade and when you turn on high beam the low beam will stay on also .
pull back slowely on the dimmer switch after dark untill the high and low are on and you will see what light power you will have with the diode installed on high beam !
have mine this way for 2 years and love it !
p.s . ckean all your grounds also and add the dielectric grease to them .
SolidJunkMM
10-29-2008 09:53 AM
robert78.5
09-28-2007 11:23 PM
greenwing
04-27-2006 10:33 PM
cmckinney
08-06-2003 01:09 AM
