96 CTD where should i start ?
Hi I got a 96 2500 4x4 with 410 gears auto trans 5" turbo back exhaust,S&B air intake,I just got a set of gauges pyro ,boost, andtrans temp.Where should be my next upgrades thanks
transmission will follow shortly after that.. Do beware tho, a 4K GSK can be quite touchy or throttle sensitive, but for five more dollars, heck why do u need more? Valve springs are a good reccomendation, but not needed per say, i dont shift past 3200 in mine.. just to avoid the valve float..
Rick
IMHO I put the 3K in for about a week then upgraded to the 4K. It is slighty more touchy than the 3K. I have not had a bit of surging ot jumping due to the toucheness. Valve springs will most likely not be a concern of yours, because you will probably not rev over 3400 with a stock auto.
Jim
Jim
CoolumConst
10-11-2008 10:00 PM
tywebb3
06-23-2006 11:30 PM
