96 2500 diesel automatic trouble with dash and charging
Old 01-10-2014 | 02:22 PM
Robert Bennett's Avatar
Question 96 2500 diesel automatic trouble with dash and charging
had a new transmission put in and that works fine put the mechanic says it won't charge and the dash instruments won't work. I think it's the wiring harness or PCM. am I on the right track? were is a trusted place to get a rebuilt PCM?
Old 01-10-2014 | 06:05 PM
patdaly's Avatar
First off, was it working OK prior to the trans?
If so, check EVERY GROUND to make sure it was put back correctly, then verify every fuse..... with an ohm meter.
Grounds cause more issues than PCMs, especially 95 and newer when they protected the 5V B+ on the PCM.
Diesel-Dan
20
09-22-2019 10:34 PM
RickKimbrell
11-12-2013 10:36 PM
GLHS
02-25-2011 11:12 PM
Smokin96_12v
01-21-2010 02:06 PM
NoSparkplugs
17
05-17-2009 11:36 PM
Quick Reply: 96 2500 diesel automatic trouble with dash and charging
