95stock- ?? what should i change.....
Hoping to get some good advice from you guys, the jeep build is getting close to having the chassis and suspension all done, and well im trying to decide on what to do for performance. I have a set of marine 370's coming, but figured i better make sure i get all my stuff lined up with some fellas who are more knowledgable than I am. What im shooting for is best amount of power that i can get before i need tear this engine down and stud the head and what not, which i am planning on doing next year, when more $$ is back in the savings account. turn the pump up, timing, fuel plate, 3k gsk, etc... what are you reccomending that i do to get me some good power, keep it together, and somewhat budgeted. Thanks!!
Randall
Randall
Well, until you have money to fix it if it breaks, I'd start with this:
Bump the timing to 15*, more if your a lucky guy, but I blew the gasket at 16.5*
Grind your plate down, a 100 profile if you have a stick, something like a 10 or 12 if its a stock auto, you'll blow that pretty quick with too much low end fuel.
Loosen your starwheel a bit, and slide the AFC and Plate forward if you want more low end.
GSK Washer mod seems to be working well, and its cheap...it'll really wake up your throttle pedal if nothing else.
Exhaust, the stock crap is like a drinking straw.
Pull the silencer ring in the turbo, no HP gains, but its a fun sound!
This will get you started, if you have an auto, hold off on the injectors, you'll blow it within a month if you put them in.
Last but not least, FILL OUT YOUR SIG!!! So we all know what your working on!
perf. mods
thanks for the ideas, ill start looking through the old threads on grinding down the plate and washer trick for GSK. even added the signature for ya guys. Pics will probably coming when there is at least a body on top. Been working on building this 4 link setup for the last week, it requires a lot of measuring and trial and error which requires emptying a lot of aluminum cans hahaha.
exhaust
The fastest way to open up your exhaust is to get rid of that 80lbs muffler and staright pipe it... I noticed a little pickup when i did that... plus it sounds A LOT better... although my neighbors ***** more now...
gscoker
16
02-17-2013 01:52 PM
tywebb3
06-23-2006 11:30 PM
