913 Pump Swap Questions?!?!
I got some questions and I'd like to have your opinions!
In a short time (been saying that for a while now) I'm swapping in a 913 Pump!
Questions are:
1. Anything I should do/have done to the pump to enhance performance before I install it?
2. What would you guys suggest for timing?
Here's the rest of the story...the pump nut on the 175 is stuck, can't get it loose with a 4' breaker bar! I have a radiator to put in sometime, so I'll probably tear the whole frontend apart so I can get to the pump easier! I'll also be doing an O-ring and ported head, and a cam at the same time, too!
Fuel wise, I'm planning on running my stock injectors, or some 215's if I can find them, with 181 DV's for a while to make sure everythings alright! Then, I'm probably going to a set of better injectors...probably EDM's and not 370's. If I still have enough air, I'll put ther laser cut DV's back in! BTW, the pump will get 4K GSK, but I'll probably try to limit it to 35-3600RPM!
I'm thinking 17* again...I do lots of towing, don't want to get good at headgaskets!
Thanks Guys, and sorry for the long post!
Chris
Questions are:
Chris
Thanks...I was gonna have our local pump guy do that, but he quit working on pump about a month ago! I waited too long!
Anyone else?
Thanks Again,
Chris
Anyone else?
Thanks Again,
Chris
Well , how about this , I'll make you a sweet deal , I'll send you a Money order to cover the shipping to send that pump up here , and I'll Pull my 160 , and send it back down for you to use while i get my pump shop to give that 913 a real good going over , and get it all turned up nice , then , i'll put it on my truck to make sure everything is copasetic.
Does that sound like a good deal? I am always trying to help out a fellow DTR'r and Farmer , even if you don't bleed Case IH red
Hmmm?! What are you getting out of this again??
I think you sound too enthused about this deal...I'm a bit leary of some of you Farmall () guys!
Thanks though,
Chris
Thanks though,
Chris
what about us green guys??????? & I mean Deutz not JD!!!! the local pump shops here charge an arm & a leg to put one on the bench, dunno if I'd bother unless you can get a good price, I'd say you've messed with enough of 'em to get it real close to the way you want it!! good luck, & how are the DV's doin'?? still good I hope, let us know how she runs after the pump, head, cam, & whatever else you have layin in the shop waitin are done! good luck again, Dusty
Deutz is the ONLY color of green...even if it is a little ugly when faded out
The DV's are still doing fine...my headgasket is probably about ready to come out of the truck and have a talk with me...I've now seen 68psi and 1650* on the stock bolts and gasket! Man am I lucky
I'll see what she's packin' Thursday night...I should have stump pulling torque, but no top end the way my timing is right now!
Keep any opinions coming, guys,
Thanks Again,
Chris
Thanks Again,
Chris
Hey Chris why don't you take it Over Too Larry at Layfette Injection and Turbo and have him put it on the stand and play with it, He is a old school guy and knows some old school tricks. He likes to talk, but you can learn o lot form him, ask Lavon about Him.
Had some bad experiences with him on a couple tractor/combine pumps...I'll pass on him for now That is unless you have some encouraging experiences to share with me??
Thanks Anyway,
Chris
Thanks Anyway,
Chris
You guys and your "even" trades...sheesh!
If I didn't know how bad Brandon needed a 913, I might do something like that
Thanks Don...BTW, hows the head look?
Thanks Again Guys,
Chris
Thanks Again Guys,
Chris
Thats cool Chris. Diff people have diff exp with people. He has always been really good to us and fast service. I go down there every once and I while and just BS and try to learn things from him. I have never had him rebuild or work on a pump for us, but he has done injector work for us.
Swamp_Donkey
09-02-2009 11:05 PM
signature600
03-29-2007 09:40 PM
ddestruel
03-03-2006 08:03 AM
