91 250 w/CUmmins need more power!! Help
Was wondering what all i can do on a budget to get more power out of my 92 250 Dodge. It has auto. trans and is 4x4. I thought about buying a BHAF and straight pipe. Is there anyway to put later model turbo on the truck? Hope you guys can help.
Straight pipe and BHAF is a good start, although neither will give you a SOP feel in power, they will allow you to use power once you give it enough fuel.
Read these articles found in the faq section:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Those should get you going pretty good. Cheap easy power upgrades.
i put about 1500 bucks into mine and it will move ya. Yes you can put a late rmodel turbo on. you pretty much gain the whistel and wider boost range. its the exhaust housing that you benifit from for quick spools.
Well first do what you were going to do and then turn your pump up and find a 12cm housing for it and you will notice a big difference cause if it is a 92 you have the 21 cm housing
Captain Dean
04-30-2006 11:01 AM
