66/12 vs 66/16
Old 02-03-2009 | 05:39 PM
chali84's Avatar
66/12 vs 66/16
i see you can buy from one extreme to the other of the sled puller 66 turbo but my question is what is the better way to go smaller or larger exhaust housing
i am going to buy this turbo but i am up in the air on the exhaust housing size
i have never really been clear about this area
can any one elaborate
Old 02-03-2009 | 06:04 PM
97 D-Tec's Avatar
if its going in that truck in your sig.. youll have a ton of turbo lag... you need waaay more fuel then that. Generally the bigger the exhaust housing the bigger potential you'll have for lag but you get less heat. but it depends on the fuel you have as well. if you have more then enough fuel to spool the 66/12 the turbo will spool quick but a ton of heat all the way to topend. if you take that same amount of fuel and add it to a 66/16 you may not spool as quick but you will have less heat all the way to top end
Old 02-03-2009 | 06:07 PM
chali84's Avatar
i will have way more fuel than what is listed but i was curious
of what size creates what effect
Old 02-03-2009 | 09:56 PM
rebal's Avatar
the 12cm will spool but
because of the comp. size it will be a little laggy the bigger the exhaust side the more power potential up high but slower spool the 12cm will choke at high RPMs EGTs will sore. with a auto trans its less a problem with the bigger 16cm
Old 02-04-2009 | 12:33 AM
97' CTD's Avatar
Go 16 stainless, spool as good as the 12 housing, no cracks, room for giggle gas.
Brandon
Old 02-04-2009 | 09:14 AM
dzlfarmboy's Avatar
What do you plan on doing with the truck and what injectors do you plan to run.
Old 02-05-2009 | 06:05 PM
chali84's Avatar
probly will start with a smarty ontop of my edge with jammer 5s cause they are cheap and later probly move to mach 6s if im not satisfied which will porbably happen any way
it will be a weeknd warrior sled puller but i still wanna be able to drive it on occasion
i only really tow small trailers with like two quads on it for races at the most
thats about it
Old 02-05-2009 | 06:56 PM
olddodgetruck's Avatar
i had a sled puller 66 i thought it was a horrible charger. my sps62 was a better turbo it ran alot cooler and spooled about the same. the sled puller only has a 65mm turbine wheel. where the sps62 has a 71mm. the sled puller usto surge alot due to the turbine being smaller than the compressor. i had the exact setup you want to do with the edge comp,smarty, 150hp injectors with the sps62 (62/71/14). is the truck a standard or auto?
Old 02-06-2009 | 12:15 PM
dzlfarmboy's Avatar
I would go for a 62/71/14 over a 66/65/14 any day. I really dont know why they make a 66/65 not the best combo.
Old 02-07-2009 | 04:43 PM
chali84's Avatar
mine is automatic
Old 02-08-2009 | 10:33 AM
97 D-Tec's Avatar
Why not the prostreet 66/71/14
Old 02-10-2009 | 04:35 PM
chali84's Avatar
i actually didnt know that the sled puller was a 66/65/14
do you have any experiance with pro street 66/71/14
Old 02-11-2009 | 08:18 AM
dzlfarmboy's Avatar
I have ran a B-1 Steroid 62/71/16 IIRC, PRO Street 66, and 64/71/13 and If you were leaning towards the pro street I would consider the Silver Bullet. I think it's a better turbo then the PS 66. And then there's also Turbonetics Hp-66/68/.84 kit http://viewer.zmags.com/publication/...38#/d150e238/1 You can go to their dodge page.
Old 02-11-2009 | 04:07 PM
chali84's Avatar
have you used a silver bullet
a lot of lag? any room for nitrous?
any experience you might have with it
Old 02-12-2009 | 07:42 AM
dzlfarmboy's Avatar
No I havent ran one but have seen alot of guys with very simular combos that look to perform better then what my PS 66 was doing. I personally think you would be better off with a smaller charger.
