64/14 or BD single?
64/14 or BD single?
Last week I bought a set of 150 horse injectors off of ebay, put them in over the weekend and wow, tons of power, lots of smoke. The pryro needle moves alot faster than it used to. I need more air, but I cant decide between an HTB2 64/14 or a BD single. If I went with the BD sigle I would eventually buy the rest of the twin turbo kit when I have the money to do it. I would like to have twins someday, so is there a kit I could buy to use an HTB2 for twins, would it work with the BD kit, or would I have to fabricate something to use the HTB2 in a twins set up? What do you guys think, anyone runnin a set of BD twins or using an HTB2 for twins?
Mike
Mike
64 should be all the turbo you need with stage4's/comp. Or for quicker spoolup look at the HTB2 62 or Phatshaft 62 over the super b, then you should be able to match a second charger down the road if needed. All these turbos are Schwitzer based: BD, High Tech Turbo, Phatshaft, B-1.
Look at PDW's page- Doug carries them all (he likes the phatshafts=p)
http://www.performancedieselwarehouse.com/996720.html
The HTB2/14 will not plug & play with the BD twins. It could be used for a BIG set of twins, if 700+ hp is your goal. It's bigger than you need/want for good street twins, IMO. You need to decide where your headed....hp wise, and when.
The BD twins are a sweet set up for up to maybe 550 hp max with min. of EGT problems. Will put out 50 to 60 psi boost so head studs may be all you need. They are coming out with a bigger twin set up this yr that still uses the BD single (S300) on top but goes with a S400 on the bottom, I believe. Their smaller, present, twins are two S300's with different turbine housings (much bigger on the bottom turbo). One of these BD sets is on my wish list.![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
RJ
RJ
Mike
Mike
Paul
grizzly660fan
01-02-2004 10:02 AM
Guy L
12-22-2003 08:25 PM
Rob1325
26
12-03-2003 01:47 PM
ROCKNRAM
11-20-2002 05:20 PM
