62/12 or super b?
62/12 or super b?
Seals are finally going out on the stocker. I can't decide on which turbo to get. I really want quick spoolup and I don't plan on adding a more aggressive fueling box any time soon. I'm very happy with how it runs now, just need to keep the EGTs under control. If possible could you guys post some dyno sheets if you've dynod with either turbo and similar mods? A dyno sheet will give me a pretty good idea of spoolup characteristics. Thanks.
With twins in your future, The Super B is easily adapted to the BD twins. And the 62/12 is a bit tight for the top half of a twin set up, IMO.
But you can't go wrong with either one. Both will spool faster than your present set up....and run cooler.
Have driven both and can't say anything bad either way. Sorry, no dyno sheets.
RJ
RJ
I have always thought the 62/12 is the best all around turbo you can get. I have the BD twins now though and love them. If you are planning on more you will outgrow the super B faster. The 62/12 is good way into the 500hp range. The Bd will be easy to upgrade to the twins kit or their R700 kit if it comes out for the 2nd gens. The 62/12 can also be made into a set with a kit form somewhere. The BD set will make good power but an s300/s4oo set will cost more. Just some pro's and con's to think about.
Pete--could you ever see high egts with your jammers and comp when you had the 62/12?
Also, I guess I may have confused terms......my main goal is minimal lag (but obviously the newer technology in these turbos will build boost faster too). My peak torque with the stocker is at 1800 rpm. I do not want to shift this very far to the right if possible.
turbos
the stage 5's always seemed dirty and hot injectors. if it was me i would go with the 62mm the super is a 57mm or check out the super b special it a 64mm. the 57 spools quick but to small in you application. JMO!!
I also forgot to add. With your truck, if you do get twins,an SO pump, mach 6's and maybe a little more aggressive box and there is no reason you shouldnt be at or above 600 if you have all the little supporting mods.
Super b single 57/65/14
Special 64/71/14
But I've been wrong before.
Had you though about one of garretts bb's turbos. A couple of guys are running them on here, not sure how they perform. They are a little more $ though.
The Super B Special would be equivilant to a 62/14. You have to work this turbo a bit harder when you are towing with it. If you are needing that much air, you are better off going to twins if you are towing.
KantDrive, I don't mean to argue with you since you represent BD, but I am 99% sure your super B Special has a 64mm compressor and 14cm exhaust housing, not 62/14 like you stated.
Just based off of the claim of 80lb/min, it is clear that 62mm couldn't support that. Or based off of 625 HP, 62mm could not support that.
No beef, just want to make sure guys don't underestimate the Super B Special, it is a real performer for sure!!!
