#6 Injector
Old 02-11-2005 | 12:25 PM
Dieselcamper's Avatar
#6 Injector
I've read lots of info on changing out injectors. Some
people say "easy,no problem" others say not so easy.
My question to those that have is, any special tricks on
replacing #6 injector. First 5 don't look to bad ,but the
#6 under the cowl looks like it may take some time.
Old 02-11-2005 | 01:53 PM
PourinDiesel's Avatar
How tall are you?
Old 02-11-2005 | 03:31 PM
justinp20012500's Avatar
Just put a 19mm crows foot on a "swivel type" torque wrench. Snap-on makes a very nice one. It torques in in/lbs or ft/lbs. It vibrates and beeps when you get to the preset torque.
Good luck.
Justin
Old 02-11-2005 | 04:35 PM
pmtg's Avatar
put some cloth around your knuckles, so when the nut breaks loose you wont smash them...atleast not too bad. its a pain, but you get over it fairly quick when the result is installed.
Old 02-11-2005 | 05:13 PM
600 Megawatts's Avatar
Muted User
Sacrafice an extra 19mm open end wrench you have and cut it in about half. Then remove that lifting bracket thats bolted to the intake plenum in the back. Do that and its not bad at all, actually its just fine. Just did another set for a friend. Total time 2.5 hours including removing the 6 injectors, changing out all the injector nozzles with stage 4 EDMs on the bench and re-installing them.
Kevin
Old 02-11-2005 | 08:16 PM
Sixpack's Avatar
As Kevin stated above... just use a 19mm stubby and it's no problem to reach it. I just installed my Don M's 1.6's last weekend! I'm all now! Take your time and do one at a time. It's no problem! Phil
Old 02-12-2005 | 12:07 AM
caper's Avatar
You guys using the cut off 19mm wrench , I assume your not torque'n #6 , just doin it by feel??Also I guess one needs a crowfoot to torque the rest ?? No way to get a socket on the lines.
Old 02-12-2005 | 10:25 AM
Muted User
Nope. I just use the 19mm open end on all of them. Using the 'that feels about right' arm torque wrench. Never had a problem with fuel leakage.
Anyway, if you are using a torque wrench on a crowsfoot, then the actual torque is not the same as the indicated torque since the devices are rotating around different centers.
Kevin
Old 02-12-2005 | 02:11 PM
Sixpack's Avatar
Same here....
Old 02-12-2005 | 02:28 PM
Bob Wagner's Avatar
For those in doubt, its best to start at #6 and work your way forward.
I must say Don~s mach 4's ROCK!
Old 02-12-2005 | 03:02 PM
Haulin_in_Dixie's Avatar
Simple job, whats a torque wrench
Old 02-12-2005 | 09:52 PM
banks twinram's Avatar
def. of a torque wrench....
Torque wrench: 1,2,3 on the impact works for me. i even tightened the head bolts on my old ford IDI with an imact, still runnin strong, 50,000 miles. and i abuse the snot out of that motor, i had a holset on it with 15 psi boost at one point in time! run it low on oil all the time, tick tick like a swiss watch
gablekevin
09-19-2006 12:12 AM
kawi600
01-26-2006 10:19 AM
G-NOTE
09-01-2005 06:36 PM
oscaroc
04-02-2005 12:14 PM
Quick Reply: #6 Injector
