6.0 vgt mounted up
Old 01-17-2011 | 10:07 PM
OrangeBlackHD's Avatar
he351ve hooked up to the downpipe. i had to post these on this thread at somebody elses request
Attached Thumbnails 6.0 vgt mounted up-vgt-222.jpg   6.0 vgt mounted up-vgt-218.jpg   6.0 vgt mounted up-vgt-219.jpg
Old 01-20-2011 | 06:31 AM
G1625S's Avatar
Originally Posted by kawi600
who knows, may use it as the secondary in compounds and have the best of both worlds.
I just picked up a core BHT3B for just that purpose
Old 01-20-2011 | 01:16 PM
kawi600's Avatar
So how does a stock VGT from a 6 liter truck stack up against, say, a phat shaft 62/12?
Old 01-22-2011 | 03:37 PM
Stock 6.0 vgt has a 58 mm comp wheel in it....62 phat is gonna b better. I upgraded mine to a 64 mm comp wheel and a 71 mm exhaust turbine.
Old 01-24-2011 | 06:32 PM
turbo will be here this week! gotta remount it and make a downpipe for it then its off to fleece to be programmed !!
Old 01-31-2011 | 06:07 PM
turbo is here and on the truck. i had to make a custom oil return line and rebend the downpipe and also had to do some intercooler tube work but its all mounted up and ready to go ! Also had to remove the shock tower and put a flat plate in place of it and use a shorter shock becasue the turbo is large in overall size. the vanes are in the full open position right now and even at 4000 rpm in neutral i cant build any boost at all...seems to flow very well in the open position and that thing whistles like a jet. Very excited to see how well it works with the vanes closed and with the controller. pics coming soon
Old 02-03-2011 | 12:41 PM
firgod4's Avatar
Let's see these pics and let us know how well it runs
Old 02-19-2011 | 03:11 PM
here are a few more pictures....been really busy lately and havent found much time
Attached Thumbnails 6.0 vgt mounted up-vgt-284.jpg   6.0 vgt mounted up-vgt-285.jpg   6.0 vgt mounted up-vgt-290.jpg   6.0 vgt mounted up-vgt-301.jpg   6.0 vgt mounted up-vgt-294.jpg
Old 02-19-2011 | 03:35 PM
AH64ID's Avatar
How are you liking it?
Old 02-19-2011 | 08:05 PM
firgod4's Avatar
looks great if u dont mind me asking how well do you like it and how much do you have into it including the cost of the turbo, im really liking this for a turbo upgrade idea
Old 02-20-2011 | 11:24 AM
i havent actually gotten to drive it yet. the turbo is all hooked up and the truck is driveable but the vanes are stuck in the fully open position. the fleece controller is not on it yet. they have the truck at the moment and said they needed to get the program set up in order to be able to control the vanes. but even when the vanes are in the full open position it really takes off once it spools up. as for cost - i paid $140 for the 6.0 turbo (ebay). and about $1500 in machining (fleece). and $800 to $900 in the controller. not to mention all the misc. costs - bolts, gaskets, adapters, shorter shock...etc. it has taken quite some time to get it all mounted up correctly. hoping fleece has the controller set up by next week im thinking its gonna be pretty sweet!
Old 04-06-2011 | 07:06 PM
almost finished here is a video http://www.youtube.com/user/BraydenFleece
Old 04-07-2011 | 07:21 AM
swordfish's Avatar
Wow that sounds nice. Clean looking install also. Well done!!!
swordfish
thejeepdude
19
06-16-2004 03:01 PM
GO 4LO
03-30-2004 12:50 PM
Battering Ram
03-08-2004 02:12 PM
DF5152
11-11-2003 10:01 PM
alan1
09-25-2003 11:48 AM
