5th gauge
#31
Originally posted by NOSPIN4ME
Where exactly are you mounting the sender?
This picture is of a boost setup but the place to drill for an intake temp sender is the same.
Brass fitting to the upper left of the yellow cap.
picture courtesy of Shovelhead , thanks!
#33
Originally posted by 2500CTD
Got a question, anyone every put a pressure gage on the high-press lines feeding the injectors?
#34
Originally posted by infidel
The pressure is close to 20,000 psi and will pulse with every injection stroke. Doubt if the gauge would last more than 60 seconds before it failed. Besides that you would have to run injector line to the gauge. It's hardened steel with a very small hole in the middle, not designed to be bent at all.
SeanB23
04-16-2010 06:20 AM
lucey
09-23-2009 05:33 AM
Patriot_RAM
10-08-2004 06:10 PM
