5897 RPMS??? Stock motor w/Juice
Old 11-19-2007 | 12:09 PM
newconcorddodge's Avatar
Just recently i was looking though the records section on my Attitude monitor and the rpms caught my eye at 5897. I never remember ever redlining it that bad, have revved it up to redline when teasing my cousin, but don't think it went that high. Usually i have a very light foot since my trans. is still stock.
So is this even possible, or is my juice messed up?
And wouldn't there be a governor on that?
I don't think its possible but what would that do to the motor?
Old 11-19-2007 | 12:55 PM
NHdodgeman's Avatar
The edge just goofed up and gave you a false reading... you would know for sure if you ever spun that rpm
Old 11-19-2007 | 04:01 PM
Mike Holmen's Avatar
The Guru
Your motor would have been junk at that kind of engine speed. Only the p pump boys run engine speeds that high and are usually highly modified.
Old 11-19-2007 | 06:45 PM
cbtumedic's Avatar
You'd probably have a nice "inspection" hole in the side of your block if you revved it that high on stock bottom end, sounds like the edge goofed.
Old 11-19-2007 | 07:12 PM
displacedtexan's Avatar
Like Mike said, the few p-pump boys that turn 5k+ have bottom end work to keep things together...
Old 11-19-2007 | 08:28 PM
Thanks for the replies, that whats i was thinking, i figured that there was no way, since nothing is broke.haha
Old 11-19-2007 | 10:11 PM
Cameronc's Avatar
just a little heads up on the monitors my buddy has a edge/attitude on his f150 and thinks his truck can do 12s now because that is what the monitor said he can do.
Old 11-20-2007 | 02:11 PM
JIT's Avatar
JIT
Mine says my 1/4mile time is 17.2 I hope that is NOT correct!
Old 11-20-2007 | 03:36 PM
JSPulliam21's Avatar
You would have never made it that high, and the block would have a couple of skylights.
Old 11-20-2007 | 05:02 PM
Well the time for the runs, is judged by the tire size, which you have to drive forward 3 rotations, then divide it. Something like that but it gives you a number to let the monitor judge the speed. If you never adjusted it then that would throw off the time it gives you.
ryan10
08-10-2007 10:38 PM
Common
05-09-2007 01:11 AM
coupdetat
02-17-2007 01:52 AM
Quick Reply: 5897 RPMS??? Stock motor w/Juice
