500 + hp set up?
Re:500 + hp set up?
OK, I'm sorry if my to the point comments go against the grain of this site. It's not arrogance, but 500 is pocket change around here. And yes Don~...we have dynos in this part of the country. <br><br>1320-I don't know where you're from, but I would contact Mark Kendrick. He sells parts and twin turbo setups. I believe he was predicting 500+ out of his ride at May Madness. Hope this helps.
Re:500 + hp set up?
To the point comments do not go against the grain of *ANY* site - personal attacks and baiting, however, do go against the grain of THIS site. You may not want to call it arrogance, but it is seen that way by many, including myself and ALL of the moderators and admins, not to mention most of the members of this site.. <br><br>If any member of this site cannot have civil conversations, without attacking and baiting people, just stay away. You know who you are, and you are being watched. Step over the line, and you will be escorted out. <br><br>Thanks for listening - sorry it has to come to this.<br><br>Joel Richards
Re:500 + hp set up?
I was over 500HP at Vegas but am over 500 when I am not in Vegas. I still drive the truck daily "it is my only transportation" and I tow my 12,000# 5er. Tuning will get the max out of any truck I only had the truck running for 3 days before leaving for Vegas, I had no time to tune after exploding my P7100 pump.<br><br>All are invited to MM 04 we will welcome all comers.<br>Bruce
Re:500 + hp set up?
The only other info I can give you is with my old pump running 13.1-13.2 @107 MPH (6400 lbs) showed like 540 HP, once the pump was sold Piers put it on the stand for a check and slight adjustment to #5 plunger is was at 488cc's@1500 pump RPM/3000 Engine, that was with a custom ground plate, Laser DV's and 4K's, now it's tweaked to 533 cc's and that is were it hit a wall! If you are looking for a stock pump to build and want more than the above get a 215 pump, but by the time you buy it and all the goodies for it you can have a race pump at the same price and it's in a different world than a stock pump, it's your money have fun with it ;D <br><br>Jim
Re:500 + hp set up?
I can make horsepower!!!!!!!!!!!!<br><br>First you feed the lod nag. She wont pull unless she has oats in the morning. After she bucks and jumps, she is ready<br>for the plow!!!!! <br><br>I had to do that. Tension breaker had to be done.<br><br>Guys with all the trucks running around you will see 180 rwhsp to who Knows!!!! I just learn as I go and haven't dynoed yet, but in June at Virginia, I will put up some numbers on a board.<br>They wont be the highest, but they will make me smile ;D.<br><br>I will not make the jump to High numbers until the old girl is retired from day to day. Then it will be a full time puller. As I will have a new<br>STUD in the field to hoss her around from place to place. <br><br>Smile everybody!!!! ITS FRIDAY!!!!!!!!
Re:500 + hp set up?
Wow, leave for a couple days....I just got back from getting my truck! Ive been around ctd for alittle while, actually have an extra in the shop.... But I m proud to say I searched far (really far ) and wide for the right truck. <br><br>I bought it friday morning, in Misourri ? sp....but the truck was from florida, I meet the seller there. I paid for the truck at 10 am friday....pulled into vegas sat morning (yes today at 9:30 am....<br><br>The good news is the truck is better then I expected......<br><br>Its a 98 quad cab 3500 duallie 4x4 with a 12 valve and 5 speed and is all red with tan leather. It has some work done, runs pretty well compared to the others I ve had experience with.. ;D ;D ;D<br><br>If you new me, you d know that it will make 500.... the only real question is when....<br><br><br>
Hummin Cummins
02-11-2003 12:14 PM
