5 inch Exhaust
Old 07-11-2003 | 07:26 PM
ed's Avatar
ed
5 inch Exhaust
5 inch Exhaust <br>I bought a 5&quot; exhaust system including muffler for my 2003 3500, ho and they told me it had a straight through muffler, but when I looked at it, it has a baffle in the middle of the muffler closing the entire opening halfway through the muffler. I called the people I bought it from and they told me it has to have the baffle for the 2003 for the turbo to spool properly. I thought the whole purpose of a 5&quot; exhaust was to open up the turbo. He said it would have a turbo lag without the baffle. Your comments and help would be appreciated.<br><br>
Old 07-11-2003 | 10:21 PM
wick's Avatar
Re:5 inch Exhaust
Bigger is not always better brother. To much exhaust flow reduces exhaust scavaging.<br><br>Its just like a race car, a high CC head with high flow #'s will be a turd out of the hole.<br><br>Were as a low CC head that flows high #'s like a Steve Schmidt head. Creates so much velocity the torque is crazy.. <br><br>A large exhaust system only looks good, the factory system with a new muffler would make more power.. Just my 2 cents..
Old 07-12-2003 | 01:49 AM
Haulin_in_Dixie's Avatar
Re:5 inch Exhaust
[quote author=wick link=board=17;threadid=16968;start=0#159070 date=1057980070]<br>Bigger is not always better brother. To much exhaust flow reduces exhaust scavaging.<br><br>Its just like a race car, a high CC head with high flow #'s will be a turd out of the hole.<br><br>Were as a low CC head that flows high #'s like a Steve Schmidt head. Creates so much velocity the torque is crazy.. <br><br>A large exhaust system only looks good, the factory system with a new muffler would make more power.. Just my 2 cents.. <br>[/quote]<br><br>All that works well for gas engines and such. The bigger the better for a turbo diesel. You don't scavange with a turbo diesel. The larger system makes more power, and lower EGT.
Old 07-12-2003 | 08:17 AM
Monty's Avatar
Re:5 inch Exhaust
Haulin is correct, the less backpressure you have on a turbo diesel, the better.
Old 07-12-2003 | 08:47 AM
bulthisl's Avatar
Re:5 inch Exhaust
Just run a 5 in. down pipe and let it dump there.<br>That would be ideal as far as your engine is concerned, but you may want it a little quieter.<br>Lose the baffle or the entire system and get youeself a new exhaust guy. He doesen't know anything about diesels.<br><br>Like said before all what he said is right for GASSERS but is not true for #2.<br><br><br> : Eddie : 8)<br>
Old 07-12-2003 | 11:16 AM
ARAcummins's Avatar
Re:5 inch Exhaust
Or just take a hole saw to the muffler and drill the center out, that well take care of the baffel, as long as it is not offset, then it is a little more tricky, but still doable. That is what we do to the big trucks. In Cal. you have to have a muffler on a semi, so we just (gut) the muffler, we you get inspected it looks like you have one but then is nothing inside it.<br>Heath
big_bear_92007
41
05-18-2007 08:11 AM
cumminsdriver635
22
03-19-2005 05:09 PM
shaft
09-01-2003 03:37 PM
bdaniel
05-06-2003 04:43 PM
Quick Reply: 5 inch Exhaust
