4x4 posi lock?
Old 01-16-2010 | 11:57 PM
newdad's Avatar
4x4 posi lock?
i bought one of these kits for my '97. just wondering how hard it is to install?
Old 01-17-2010 | 12:00 AM
8UPRACIN's Avatar
Its not too bad. Just routing the cable down to the axle is tricky cause you gotta make sure it doesn't rub anything or get in the way of the suspension. I used some big Zip ties to hold it to the back side of the axle. You'll be glad you got it. I use it all the time moving my big enclosed trailer in 4 Low cause the Dual Disk is so grabby trying to idle trailers around. Chris
Old 01-17-2010 | 12:05 AM
newdad's Avatar
thanks for the input? someone told me once that you have to adjust the cable or something? anybody have any input on this? how hard is it to turn the **** when its hooked up properly?
Old 01-17-2010 | 12:09 AM
8UPRACIN's Avatar
Its not too bad to adjust. You just want make sure the transfer case is in 4wd when pulling the cable. It helps line up the collar when connecting the axles internally. Once its pulled I normally just give it a twist out to make sure its good and tight.
Old 01-17-2010 | 12:31 AM
newdad's Avatar
oh is it a push/pull system?
V.R.Wheeler
08-04-2007 02:00 PM
jmccart
07-10-2007 12:46 PM
jmccart
07-07-2007 01:46 PM
atc250r
05-23-2007 12:29 PM
TxDiesel007
07-29-2005 03:47 PM
