4WD Launching
Old 09-06-2006 | 08:17 AM
berner's Avatar
4WD Launching
My buddy figures my truck is a POS and I'll get my doors blown off by a stock 3rd gen a friend of his has. So it's drag race time. I roast my tires doing a 6 lb launch. How are you guys going about launching in 4WD? When do you shift back into 2WD? Do you let off the throttle when you shift? Thanks
Old 09-06-2006 | 09:35 AM
Mcmopar's Avatar
Leave it in 4wd until you go through the traps. It will not disengage until you let out of it for a sec. anyways.
Old 09-06-2006 | 10:06 AM
RowJ's Avatar
I slide it out of 4x4 about half way down the track... just out of habit. As stated, it won't release till you let up. Some places I race, it's a full time job getting stopped before the pavement runs out .... and it's easy for me to forget about 4x4 till I try to turn off the track
RJ
Old 09-06-2006 | 11:16 AM
Mike D's Avatar
I would say if you launch around 10 psi you'll take a stock 3rd Gen. Are you racing at a track? If so, leave as soon as you see the last yellow.
Old 09-06-2006 | 11:37 AM
1-2-3's Avatar
Just a plain ole guy
So your going to risk tearing up your truck just because someone said they can beat you?
Old 09-06-2006 | 11:43 AM
Timmay2's Avatar
Yeah, hes a man aint he?
Old 09-06-2006 | 11:45 AM
RJF's Avatar
RJF
Take it out of 4wd? Last time I was at the track I shifted into 4wd as I pulled into the staging lanes and I shifted it back to 2wd 4 hours later headed through the exit gate out to the highway.
Old 09-06-2006 | 01:34 PM
paulb's Avatar
If I could make the return road I would do the same thing!
Paul
Old 09-06-2006 | 02:12 PM
CSAGrey1's Avatar
EDIT Yes!! The mans pride in his work and rig are at stake. That's racing!!
Beside if he get's stomped by a stocker it will give good indication of what has to be done yet.
Old 09-06-2006 | 03:35 PM
Teddy Bear's Avatar
Agreed!!!!!!!
Old 09-06-2006 | 04:43 PM
blackdiesel's Avatar
Registered
and he wouldnt because......????
Old 09-06-2006 | 04:49 PM
Jambbii's Avatar
Dont launch any higher than 10 psi. You might risk taking an output or input shaft out.
Old 09-07-2006 | 08:29 AM
berner's Avatar
This guy's been my best bud for 37 years. He's jealous because he drives an AstroVan. He's always telling me this guy's done everything to his truck that you have and more, that guy's got the Banks, 24 valve, best of everything. He's diesel illiterate. He needs shutting up.
He's telling me the stock 3rd gen beats Hemis. Is he full of #^@? Do they really go that good? What's the ballpark 1/4 times that they'll run?
Oh, and thanks for all the tips.
Old 09-07-2006 | 08:38 AM
2500CTD's Avatar
Not sure what they run, but I raced a 3rd gen and we were even. I consider myself mostly stock.
Old 09-07-2006 | 08:39 AM
RowJ's Avatar
How about 'don't launch higher than 0 psi'?
Safer with a stock turbo... yes. Many have no trouble below 10 psi...yes, for a while.
But it appears you already know that... from your signature
2500CTD - You are 45% over stock @ 274/580. Any stock 3rd gen will beat any stock 2nd gen, IMO.
RJ
