4k GSK Tuning ???s
4k GSK Tuning ???s
I installed a 4k GSK with the valve springs awhile back. In the middle of the install I dropped my calipers and goofed up the measurement of the nut that holds in the gsk. Is there a easy way to balance the GSK springs? It doesnt want to rev much past 3200 when I had 3600 before with the 3K springs.. TIA
Id say give it another 3 clicks tighter on each side, and try that. It definately needs to be tightened up if you arent getting what you had before. Its no big deal really, just play with it till you get it right. Good luck
Eric
Eric
Eric
Eric
Eric is right
OR you can loosen it up all the way till its one click from off, then go two clicks at a time on each side till u get it right or any number of clicks, i dont member how many it is to get it to .55, but its where mine is at...
Rick
SHARPMACHINE
03-06-2007 08:45 AM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
