4k gsk questions....
Alright I put the springs in and the truck runs pretty good. Idle was a little high so I know the springs may be on the tight side. Can I do any damage by having them too tight? The truck is harder to start in the mornings and will sometimes drop rpms real low when I put it in gear and the engine is cold. Also the truck is very respsonsive on the lower end, maybe too responsive. Dont want to break anything just yet
Thanks
Thanks
Re: 4k gsk questions....
Originally posted by Jambbii
Can I do any damage by having them too tight? the truck is very respsonsive on the lower end, maybe too responsive.
They say Ideally if you get them back in just the right adjustment your idle will stay the same.Mine did, but i used a marker on the top retainer so i could get a rough measurement with the caliper and then line up the mark so its in the same notch it was to begin with.Mines a little touchy when cold but drive a couple miles and i never notice it
SHARPMACHINE
03-06-2007 08:45 AM
MR HYDROSEED
03-09-2005 10:49 PM
Got Smoke?
10-26-2004 03:57 PM
