4BT performance ideas
Hey guys I'm new over here and I just picked up the 6BT's little brother, a 4BT to put in a ford Ranger. I was just wondering all of the little things you can do to a 4BT. Are the injector pumps similar to the early dodge style? I plan on running a 4" strait pipe and 3" intake pipe intercooled through a 500hp rated bar and plate intercooler. I don't want to go too crazy maybe hit 200hp or so. I'm gonna just toss it in the truck the way it is then run it for a while til i can find time to do performance mods. Should the stock lift pump be enough for my app. or should I look into an aux. electric? Thanks guys.
Yeah I will be interested in this too. I was thinking of putting one in my 74' IH Scout. I am told that any of the 12v injectors are fine with it, since its essentially the 6bt with two cyls chopped off?????
I was thinking 370's and an HX-30/9 turbo with it would make a nice setup.
There is a guy who floats around here that has one in a ranger and has run 11's I believe. I think he runs lucas prince of darkness injectors and an HX-35/12 on it. But I would think that would be a bit much on the street.
KP
KP
I'm pretty sure I have a rotary pump. You guys think 3" is enough to support 300hp or will 4" be just a bit safer? I dont want to build it twice in case down the road I decide to hotrod the thing out. 4" wouldn't hurt as long as I could fit it right? From my gasoline turbo days I always followed the plan of putting the biggest downpipe possible.
https://www.dieseltruckresource.com/...ad.php?t=84054
This thread has real good info in it!
600 Megawatts
02-11-2008 11:07 AM
JimmieD
16
07-02-2006 12:37 PM
