48RE Valve Body/47RE Tranny
The Guru
Storx, how are you breaking so much stuff? Mine has held up with little or no issues at 677rwhp for the last three months. Trust me I have put my foot into it a few times.
if i only knew.... mine keeps braking stuff when im boosting upwards of 70PSI
The Guru
These trannies are pretty tuff considering that they where designed to run on 200rwhp engines. I have pull some big boost numbers but nothing close to 70psi. I would be taking the tranny back and get the shop to findout what going on with that tranny. Your pulling some big numbers but I wouldn't let that be an excuss for your tranny issues.
see goerend bros has sent me all the billet parts... upgrades and suck but he is use to trucks the tow a lot.. and are not under max acceleration for 1/4 mile runs haha... he builds a tuff tranny and all his parts are good... but he told me himself that im the first person to tear up one of his triple disk converters.....he ios trying to help me also but everything we keep trying either leads to something else breaking or not wokring as planned... he is really trying i give him this.. he send me parts free overnight.. on his expense because ive broken stuff at the track... i never would expect that from any other tranny shop.....so i thought i would ask while i wait for him to play with setup for my tranny so i can throw ideas his way.. see when he designed my tranny and torque converter he tests these off od a big block chevy engine he has rigged up putting like 800's hp and like 1100's torque... and im running numbers higher then that so im going beyond what he has designed most of his stuff to be reliable up to......im not trying to make his stuff sound weak or horrable at all.. if it wasnt for him i would be in a lot serious problems right now..... i use to have a ats/ats converter setup and it was GARBAGE FROM THE START... and they wouldnt even do the warranty work because i was running to high of torque for what there tranny was rated that they failed to mention before hand....
yeah... he is so tempted to just barrow my truck for a week or so and take the engine out and test everything on a mockup... haha i mentioned it the other day and he laughed then shortly afterwards he asked me if i have another vehicle to drive.. haha....
i dont know i ran it at the track yesterday after doing 5 friction/5 steel i was advised to try and i was surprised on how well it held.. haha i got the pictures to show how much wheel spin i had on the launchs...
yeah i have my time slips why?......
also the local tranny shop went ahead and bought a 48re valve body the owner wants to play around with it and see if the 48re valve will hold better in the 47res because they are the same price and he will just start using them now on for rebuild units.....
storx
Why? No big deal just wanted to see the 60' and 1000' numbers. Glad things are working out for you. As you are going to find out there are several other things you will have to address and readdress if you plan on utilizing that hp.
Originally Posted by OPIE
storx
500.00 Car
2,200.00 Engine/Tranny
550.00 Tunable~~HackTop ecu
150.00 P550 injectors
200.00 130mm Pump
125.00 Reman Turbo
4,175.00 on a possable 11-12 sec diesel car when done.....
47 RE or 48 RE
What tranny?? Mine is an 03 SO Auto. In the glove box is DG8 = Transmission - A. DGP = Transmission - AU. So what is the tranny?? Anyone able to help? javahjoeo
S/P G671
09-30-2009 11:33 PM
Bersaglieri
22
11-05-2007 11:30 PM
